HotPoint WMA61P no motor action
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries HotPoint WMA61P no motor action
  • #25036
    Machine don’t show any error but motor isn’t move a bit, neither any relay clicks (is not activate any relay).
    On wash program: fill with water until pressure switch commute. I didn’t check if heat.
    On spinning program discharge and, also without motor motion, time is counting down…
    Any ideas? … test for this machine or manual? 8)
    No:87124963
    #204293
    Re: HotPoint WMA61P no motor action
    Will send you test info on the WMA63, almost the same AFAICS
    I did run “TEST” and doesn’t reveal any error but on step:
    13 rotate on both parts at 90rot/min for about 4 minutes (instead of 20sec)
    14 rotate at 1000 rot/min for one minute
    15 skip (this one has 1600rot/min and believe that I know how should sound at maximum speed)
    16 OK
    Question: how can I read last error? if it is recorded (available)…
    Thanks for previous info Jim
    #204295
    No mention of last error codes in WMA62/3 manual.
    Sounds like a possible bad contact on motor harness :con:
    Alanj
    Hi Baron,
    have you checked for broken wiring near to motor plug,sometimes broken inside insulation?
    Alan
    #204297
    Another posibility 😉
    http://tinyurl.com/25kbw2
    #204298
    Thanks also for second info.
    I have run again test and at begining shows E18 (excesive unbalanced).
    I’ve checked machine on my desk (work table) and had run good… only at finish (spin part) he had some difficulties on getting higher revolution (never activate secondary part of stator). He didn’t stoped because of one error.
    So I have to wait until change bearings (need to be replaced) in order to see if the fault is still there.
