Hotpoint WMA62s
  • #45171
    Galway
    Any tricks to taking out inner drum to get at bearings .it wont budge! 💡
    thanks
    #283892
    LJDomestics
    Re: Hotpoint WMA62s
    sometimes a little nudge in the right direction with the pulley nut on and a wooden block and a decent sized hammer can free it off.. but go VERY CAREFUL or u could damage the shafts thread, spray a bit of wd on there first also.
    #283893
    spimps
    Re: Hotpoint WMA62s
    Almost lump hammer size 😯 ,sometimes the bearing comes out with the shaft,a brass or copper drift will also help.
    Worst scenario is a new drum shaft which will make a better alround repair anyway,shaft and bearings together are cheap enough,I’d be tempted to consider changing both.
    #283894
    Re: Hotpoint WMA62s
    i use a tap to clear the blue anti shake compound from the spider thread then find a bolt and washers to screw in the back of the spider then belt seven bells out of it with a lump hammer. you can spray wd40 down shaft to try to help but in effect it can be brut force and hope the plastic does not give way
    Re: Hotpoint WMA62s
    Yes, I had one where the whole alloy bearing housing broke off the back of the tub. They do rust in well. 🙁
    #283896
    spimps
    Re: Hotpoint WMA62s
    Phidom wrote:Yes, I had one where the whole alloy bearing housing broke off the back of the tub. They do rust in well. 🙁
    😯 athletics could do with a decent hammer thrower,how you fixed?
    #283897
    Galway
    Re: Hotpoint WMA62s
    cheers will give it a go!
