Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WMA63 bearing
- This topic has 8 replies, 5 voices, and was last updated 21 years, 7 months ago by
admin.
August 17, 2004 at 10:26 am #6047
KeymasterI am trying to remove the inner bearing on a Hotpoint WMA63 washing machine. The rear bearing knocked out with no problem as did the front seal but the inner bearing had already disintegrated and only the outer casing was left.. Is it possible to remove this without specialist tools?
August 17, 2004 at 11:20 am #115288Dave_Conway
ParticipantRe: Hotpoint WMA63 bearing
It should come out with a good wallop, make sure whatever you are using has a good edge on it to make good contact with the outer bearing shell.
August 17, 2004 at 11:31 am #115289admin
KeymasterRe: Hotpoint WMA63 bearing
I have tried giving it a bl@#dy good wallop with a big hammer and large screwdriver but its only budged about a milimeter. There doesn’t seem to be that much of an edge to hit. As the bearing only has the outer case left it is almost flush with the steel insert. (which I guess stays in place?)
August 17, 2004 at 1:52 pm #115290Martin
You will need a long 8mm drill to drill 2 grooves (5mm deep) in front of the bearing into the aluminium collar support. Then use a cold chisel to drift the bearing out of its ‘blind hole!’
Easy 😆
August 17, 2004 at 8:35 pm #115291SparkyP
Yes these are stubborn little so and so’s. Do as Martin says get a flat edged chisel and a lot of patience. You say you moved it a mm. Pesevere and it will come out. Just make sure you get a good hold on the bearing case with the chisel or a long thick screwdriver……………Good luck. Remember patience not frustration and you will conquer this.
Sparkyp
August 23, 2004 at 9:31 am #115292admin
Drilling 2 grooves in behind the bearing and a big hammer sorted it..
Cheers for the suggestions..
September 10, 2004 at 9:55 pm #115293admin
a little help on drifts
an engine valve stem is a handy tool for drifting out items where a small lip is available as on a stubourne outer case of a bearing.
also an engine push rod, if ground down to suit job (do not over heat)
but a good mechanic always uses a brass driftSeptember 11, 2004 at 4:19 pm #115294streetlighter
hi all
what about getting the drum support bolts undone then 😈
Any ideas on that would be appreciated 😆paul
September 11, 2004 at 5:05 pm #115295Martin
streetlighter wrote:hi all
Replied to you on this in Trade Technical (see link below)
Martin -
