Hotpoint WMA63P
  • #15778
    Flyman
    Four year old. Select just a spin and it spins ok and finish’s the cycle. However if you select a rinse and spin or a wash programme it goes through the full spin until the display gets to 1 minute then it sticks on that. It repeats the fast spin sequence pauses then repeats it again and again and again 😡
    Control module, facia module and connecting cable have been changed. The motor wiring harness had been rubbing against the front weight but that has been repaired and tidied up out of the way. Motor, element etc. have been checked for earth faults and everything checks OK. Any help appreciated 😀
    #166296
    Re: Hotpoint WMA63P
    Can send you a wiring diagram and the test procedure if you wish.
    #166297
    Flyman
    Re: Hotpoint WMA63P
    Thanks Iadom but already got it and still can’t work this one out. Trying new pressure switch and pcb to motor harness next out of desperation 🙄
    #166298
    Re: Hotpoint WMA63P
    I know what you mean, I have one of my own ATM, a WMA42, door would not lock, tried new door lock, machine started to work fine then after a couple of minutes the door lock de energised and the machine cut out. Machine fairly new, wiring harness perfect etc. Changed module, the module I used had been repaired by QER. The only thing I found unusual was that when configuring the replacement board at the third step where Option lights 2 & 3 should be flashing the ‘Final Spin ‘ LED was also flashing. Configuration seemd to go OK after that and the machine then ran on spin, rinse & spin and wash seemingly perfectly. Had a call today, customer says that she selects a programme, wash.rinse, spin LED’s light up, she presses Start and nothing happens. I went back today and without moving the machine did the same and the darned thing worked perfectly, I could not get it to fail. left it washing away merrily, she has just phoned to say it is doing the same thing again. 🙄
    Think I might try a new Hot valve. 🙂
    http://www.ukwhitegoods.co.uk/modules.p … highlight=
