Hotpoint WMA63s
Viewing 15 posts - 1 through 15 (of 17 total)
  • #39085
    pmac
    HI there
    I have a 7 year old hotpoint wma63s. The bearings appear to have gone – terrible rumbling/ knocking and about 5-10mm play on the drum. The machine is fine otherwise, is it worth repairing? I am mechanically minded and feel I could take the job on myself, if it is worth doing.
    If I did the job I would get the bearings and tub seal, would it be worth getting the drum spider as well? Is there anything else I have missed out?
    Any advice is greatly appreciated.
    Many Thanks
    pmac.
    #261250
    hotpnt
    Re: Hotpoint WMA63s
    hi, not the worst to change, personally i do 50/50 bearings/rear half complete, depends how it looks when you strip it down, drum needs to come out, (not hard), then seperate the 2 halves, (easy), only when you get the inner drum out will you know if you need a spider,
    the bearings can be knocked out & replaced, easier way is to fit a new rear half, with bearings already fitted, plus a new seal for between the 2 drum halves,
    All the parts can be obtained from the shop@ here,
    As for being worth repairing, the WMA are a well built machine so i would say its worth doing,
    Any questions you can pm me
    Hope that helps
    #261251
    pmac
    Re: Hotpoint WMA63s
    Thanks for the advice, I think I will have a go at repairing it. As the machine is still in use, I would rather get all the parts before I take it apart. As the bearing is well knackered (when you spin it by hand, when it slows down, the drum will “drop” on the shaft / bearing) do you think it is worth getting a spider and replacing it as a matter of course, to save downtime on the machine?
    Thanks Again
    pmac.
    #261252
    Re: Hotpoint WMA63s
    The spider is usually OK on these as it does not have a bronze bush to get damaged like you get on most other machines. If you do order a spider you should also get new fixing screws as they rust in. The most difficult job will be removing the outer race of the front bearing. The front bearing is nearly always in bits, balls broken in half etc.
    #261253
    hotpnt
    Re: Hotpoint WMA63s
    pmac, just a check first, but if you say the inner drum ‘drops’ does it sound noisy if you turn the drum by hand whilst supporting the inner drum?, as i have seen these supports break on their own, which often gives the knocking noise and would also mean the drum ‘drops’, the other way to check if its bearings or support, is, remove the top,(with the plug out of course) move the inner drum up/down where the play is, if the pulley on the back moves with the play its bearings, however if the pulley does not have the same play, it will be a broken support
    #261254
    pmac
    Re: Hotpoint WMA63s
    Thanks for the advice guys. Stripped it down this afternoon, as it sounded terrible on a wash this morning! It came apart ok, found the rear bearing ok, but the front one had totally collapsed – it was just running on the inner and outer races – some of the balls were actually gound in half!. Got the old races off and cleaned up the sleave and shaft – no damage to these at all, the old races bore the brunt of it – how lucky am I? (wish I had bought a lottery ticket)
    I have ordered a new bearing set and a tub seal from the shop on here.
    I have also given it a thorough clean in readyness for the new parts.
    Should do another 7 years now!
    (will also replace the rear bearing as well)
    Thanks Again.
    pmac.
    #261255
    Re: Hotpoint WMA63s
    Yes, you must fit all parts of the new bearing kit. Which bit do you mean when you mention the “sleave”?
    #261256
    pmac
    Re: Hotpoint WMA63s
    What I call the sleave, is the alloy bit in the tub that the outer races of the bearings sit in. I don’t know it’s proper name!
    Hopfully new parts will turn up tomorrow, so I can get the thing working again.
    pmac.
    #261257
    hotpnt
    Re: Hotpoint WMA63s
    yep that should be fine for you then, just be sure to tap them in evenly, worth running some emery tape round the sleave/collar 1st to remove any rust, i then give a quick spray with some spray lubricant to help them back in, also be a bit carefull with the seal infront of the inner bearing, will be either metal on 35mm or rubber on 30mm sets, take care that it fits right in tight & flat,
    #261258
    grazzamongrel
    Re: Hotpoint WMA63s
    it is always best to replace the rear drum half and not just the bearings.
    #261259
    hotpnt
    Re: Hotpoint WMA63s
    no, if the old ones come out, its not a problem, as i mentioned, ive fitted many bearing sets without any problems, (so far!!)
    #261260
    pmac
    Re: Hotpoint WMA63s
    Thanks for all your valued help and advice.
    Fitted the new parts, and put it back together today. Its like a new machine, it is so quiet now, you can hold a conversation whilst standing next to it! Did a “service wash” to get rid of all the crud I disturbed, and now the wife is catching up (trying to kill it again!) with the washing.
    Thanks Again for all your help and advice.
    pmac.
    #261261
    Ger
    Re: Hotpoint WMA63s
    Hi All,
    I am aware that this is an old forum that I am tagging onto but we have the same problem with our WMA63 washing machine and this forum explains it very well.
    I am trying to decide between buying a bearing kit or a complete drum.
    I have removed the drum from the machine and removed the front of the outer drum but I can not see how to remove the inner drum from the rear outer drum. Do I need special tools?
    Any advise would great.
    Thanks Ger.
    #261262
    grazzamongrel
    Re: Hotpoint WMA63s
    yep a stupidly large hammer should do the trick
    #261263
    Ger
    I was afraid of that.
    Do I use the screw hole for the pulley wheel to pull the shaft back into the new bearings?
    How is the seal put in place inside?
    Looking online I can get a complete assembled drum for £160. Maybe this is a safer bet.
    Thanks for the info.
    Ger
