Hotpoint WMA64 how to get into diagnostic programme
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WMA64 how to get into diagnostic programme
  • #21024
    Seamy
    Got a Hotpoint WMA64 (ultima 1400) left by a customer outside my premises with a note on it overnight in the wet, not spinning it says. Turned upside down 😆 , checked motor, brushes OK. Cleaned armature, no visible damage to loom. Any ideas, pump runs but no motor action at all.
    What i would like is details of how to get this machine into diagnostic mode so i can access fault history etc..
    #189204
    Re: Hotpoint WMA64 how to get into diagnostic programme
    Glad to hear you got e-mail, hope it helps.
    DDSDDS
    hello jim any chance you can send me that as well ta m8y
    danny
    #189206
    Seamy
    Thanks Jim, i run the diagnostics programme on this & low & behold it worked in the test programme & in every programme used after, did this just need reprogrammed to go again? I hate it when i don’t know whats caused the problem! Oh just another thing this machine is the variant with the module & power board all in one.
    #189207
    Seamy wrote: Oh just another thing this machine is the variant with the module & power board all in one.
    Looking at Partfinder I cannot see a model of WMA64 with combined control/power module, are you certain. ❓
    #189208
    Seamy
    All cabling from motor went direct to power board, i think, i used the wiring diagram you sent me to try & trace wires, it showed motor loom to chopper board, then from chopper board to power board. On this machine there is only one board (that i can find) located piggy-backed behind facia panel. Also there are more connections on board than on diagram so i presumed its a combined board.
    #189209
    Wiring is different but test procedure seems to have worked.?
    There is no Chopper board on these, only on 1600 spin models, what you have is the Control module & Power module.
    #189210
    DDSDDS
    Any chance of the diagnostic details for this machine please jim?
    #189211
    phil59
    can anyone send me a copy of the test procedure many many thanks in advance
    phil
