Hotpoint WMA66P
  • #54407
    maltheviking
    Machine runs OK until the end, then after final spin and before the door interlock disengages, it starts to “pulse” the water valves. 😕
    Anyone got a clue whats going on before I order a new PCB?
    #319490
    johnnyj
    Re: Hotpoint WMA66P
    Had a door lock causing that once with a wma, might be worth trying that 1st JJ
    #319491
    adv
    Re: Hotpoint WMA66P
    or mibe motor had that 😆
    #319492
    Re: Hotpoint WMA66P
    Odd indeed. Have had one which pulsed water valve during spin and it was down to low brushes on the Bosch type motor (thanks to P45’s advice). You’ll need the dual tag type brushes I expect. So I’m with adv on this.
    Mike.
    #319493
    maltheviking
    Re: Hotpoint WMA66P
    leavemetogetonwithit wrote:Odd indeed. Have had one which pulsed water valve during spin and it was down to low brushes on the Bosch type motor (thanks to P45’s advice). You’ll need the dual tag type brushes I expect. So I’m with adv on this.
    Mike.
    No Mike, this is doing it after the spin
    #319494
    adv
    Re: Hotpoint WMA66P
    phone emw
    #319495
    Re: Hotpoint WMA66P
    Might be worth trying a doorlock first, nothing to lose really.
    This was a common fault caused by Vestel door locks a while back and its basically the same part.
    #319496
    Re: Hotpoint WMA66P
    Yeah, I know, I read your post. But I still think anything’s possible with these fancy electronics.
    Mike.
    #319497
    maltheviking
    Re: Hotpoint WMA66P
    Well I have to give Johnnyj first prize, :beer: twas the door lock 😕
    Opened it up and the plastic around the heat pellet had carbonised, obviously causing spurious shorting, thanks all :tup:
    #319498
    Re: Hotpoint WMA66P
    🙁 Brushes’ll probably go next month. :snigger:
    Mike.
    #319499
    maltheviking
    Re: Hotpoint WMA66P
    leavemetogetonwithit wrote:🙁 Brushes’ll probably go next month. :snigger:
    Mike.
    yeah sods law, il’l get you a beer anyway :beer: :snigger:
