Hotpoint WMA74P Residual soap in drawer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WMA74P Residual soap in drawer
Viewing 5 posts - 16 through 20 (of 20 total)
  • #475619
    I think I got mine from local Asda but sounds like you need something bigger. 🙂
    #475620
    Think I got mine from local Asda but sounds like you need something bigger. 🙂
    #475621
    touran daddy
    thanks
    Think I’ll have to use the pre wash compartment. No matter the temp selected it blasts in there first then switches to main compartment.
    even after stripping it all down it still does it with new powder. I can only assume the top spray lid is worn and not jetting correctly.
    I could try removing the restrictor in the inlet valve I suppose.
    #475622
    There is a reason why the machine fills through the prewash drawer first. This is to allow a small amount of water into the drum to lift the plastic ‘eco ball’ located in the sump. This prevents the detergent from being flushed directly into the sump and keeps it all in the drum for best efficiency. A new detergent drawer should fix the problem.
    #475623
    touran daddy
    Thanks iadom
