hotpoint WMBF963 overfilling since module repair
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint WMBF963 overfilling since module repair
  • #98996
    snig
    Above machine had a blown module, i assummed due to obvious interlock fault. Had module repaired but now wont drain on spin programme and just keeps filling .Am i missing something else before i send module back for testing ?
    #474625
    snig
    just to add, machine filled to level on wash and had motor action, but put to spin to empty out and it just filled, even after i cancelled the programme
    #474626
    nothing i can think of
    have had them do this, when they go into fault they fill and fill
    does it show any fault code ?
    kaibart
    Who repaired the pcb if its emw pcb is probably faulty
    #474628
    snig
    No fault code but suspect module as was powering fill valve even when off !!
    #474629
    murv
    Can’t think of anything but the module. Do you have a matching one from an old machine that can be reprogrammed to suit?
    #474630
    sounds like a shorted triac
    is this repair U/G
    murv
    As Dave said, if it’s an early board it will most likely be a shorted Q29 or Q27. Can be Triac with VDR protection or an AC Switch in these positions.
    Murv…
