This is the machine with the induction motor and big alley heatsink on the control board.Machine started to fill and defaulted.No motor action or pump even on a spin only cycle.Machine will unlock on pause a couple of times and then that stops working.This all happened when machine was not in use.Would I be correct in assuming the control board has failed.
Can I ask if you ever got to the bottom of this one Winker ? I came across one of these doing the same today and I’m wondering if I should send the customer to hotpoint ❓
