Hi all
Just a quick query
Had a call to look at one of these machines, customer said that water poured out from underneath as soon as it filled… Door seal was fine, so took a look underneath.. There were no holes in outlet hose, but the pump was wet, so fitted a used pump I had with me just to be sure.
Leak was still the same.
I have since taken the outlet hose off and have another on order, for fitting tomorrow
Are there any known faults/updated parts with these pumps or hoses…?
Only thing I can think off is the hose is not fitting correctly due to age etc
