hotpoint WMD740P(UK)R dispenser leak
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint WMD740P(UK)R dispenser leak
  • #72113
    hilly
    this model has the rotating drawer and when it fills for the conditioner it leaks, ive replaced the top part of the dispenser (coo115914) and the valve but it still does it?
    help pls!! :bang:
    WMD740P(UK)R
    912167223
    30678960000
    cheers paul
    #383496
    madangler1
    Re: hotpoint WMD740P(UK)R dispenser leak
    Did you clean the hole the conditioner siphons through? . These block and it spills over. If that’s ok Iv also seen crap buildup in the jets forcing the water in the wrong direction.
    I offen remove the whole thing. Split it and thoroughly clean it then refit.
    #383497
    helo_75
    theres a modified drawer for that
    cant remember the number though…
    #383498
    hilly
    madangler1 wrote:Did you clean the hole the conditioner siphons through? . These block and it spills over. If that’s ok Iv also seen crap buildup in the jets forcing the water in the wrong direction.
    Siphons are clean and I’ve replaced the top and valve but its still leaking?
    Shite machines!
    #383499
    madangler1
    It’s the water pressure high as if it is it will overrun the draw. It’s a simple system water fills to the top of the tube that is covered by the tube on the cover, this begins a syphon and drains the conditioner, either to much water is going in to fast or it’s not syphoning.
