Re: Hotpoint WMD940 Rinceing Twice
Hi there, Coins in the pump wont usually cause this problem. it sound like the taco is open circuit this is a small coil located on the end of the motor that put simply, sends signals to the module to regulate the speed of the motor. check the wires as they come out of the taco and as they enter and exit the motor plug then on to the module the wires can break any where so a continuity tester would come in handy but usually the break is quite obvious “Q”
