A little bit of help or even alot of help would be most appreciated on this one .You turn m/c on door locks and then nothing she said she did get f01 come up once. it dosn`t matter what you select no fault code appears F01 says motor triac or earth fault.But surely it should do something.And is there a test cycle for this m/c . thanks in advance 4 your repplies
Had similar last month – door locked and then nothing. sent board to EMW but they said that the chip was damaged and were unable to repair. As this was for a letting agency that I do a lot of work for I had to fit new module and treat myself to smart card reader and pleased to say machine worked OK.
May be worth sending board to EMW for test/repair.
