Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint wmd942 doorlock issue
- This topic has 9 replies, 4 voices, and was last updated 11 years, 12 months ago by
mark1983.
April 14, 2014 at 2:50 pm #80314
mark1983
ParticipantHello to all and ive got a problem! … I have the above machine for 3 years were well I thought the door lock has failed , so I got a new replacement which didn’t do the trick.
I then checked the wiring from the main board to the switch, all the wires checked out ok using my multimeter on continuity,e so with photos taken ive removed the main board to investigate.
Ive found a resistor on the board to be damaged , the tracks from this resistor lead to the door switch loom so it looks like the culprit but its so damaged I cant recognise it , its in the R369 position on the board and the board is a Delta EADP-C002-1 , ive also attached a photo to help identify the component
Any help would be great and thanks for having me here
April 14, 2014 at 2:53 pm #412416iadom
ModeratorRe: Hotpoint wmd942 doorlock issue
No sign of your picture?
April 14, 2014 at 3:01 pm #412417mark1983
ParticipantRe: Hotpoint wmd942 doorlock issue
April 14, 2014 at 3:20 pm #412418iadom
Now just have to hope that someone has a pcb they can have a look at to compare. This type of info is not supplied with any technical specs. 😥
April 14, 2014 at 4:31 pm #412419big3card
would be ashame to scrap it for this ?
April 14, 2014 at 4:57 pm #412420mark1983
yes it would be ashame , its been a good washer fingers crossed
April 14, 2014 at 5:39 pm #412421iadom
mark1983 wrote:yes it would be ashame , its been a good washer fingers crossed
It is a 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} Indesit made machine with very ropy electronics, a totally sealed drum etc.
I scrapped a Hoover machine this morning, the metal back panel had corroded through but it was 22 years old. that’s a good washer. 😉
I have a picture of a WMD960 pcb but it is completely different to that sadly.
April 14, 2014 at 5:54 pm #412422Andy jones
If you’re convinced the board has blown you could try Emw electronics that may be able to repair it for you, but as said these are poor quality machines. I seem to condemn an awful lot
April 15, 2014 at 8:37 pm #412423mark1983
ok thanx for all replys still looking to identify the component in r369.
April 24, 2014 at 9:40 pm #412424big3card
Hi to all , changed a drum/tub assembly on one of these Monday and took a quick pic for you (R369) .. hope you or someone here can identify your component or take it to maplins with your board… Best of luck
