Hotpoint WMD960
  • #59011
    TheSpinDoctor
    Hi all.
    I wonder if someone would be kind enough to help me with this one please. I have one of the above machines to look at. I don’t usually work on Hotpoint so have no idea on fault codes or diagnostics here but basically what happens is that the door will lock when the start/pause button is pressed, the time counts down but nothing happens. No fill, no motor action & if put onto spin, no drain either. I have had the pump off & the impeller is free running. The machine is just over 2 years old & has no previous history of faults.
    Any ideas/suggestions greatly apprieciated.
    Thanks in advance.
    TSD.
    #336469
    jonnieboy
    Re: Hotpoint WMD960
    first check is for worn out motor brushes failing that broken wire at motor plug
    hope this helps
    #336470
    Re: Hotpoint WMD960
    If you do find worn brushes it will be a first, 3 phase motor in these. 😉
    No diagnostics to speak of but fault codes are in the Error Codes thread.
    As jonnieboy says motor wiring is a possible cause.
    Re: Hotpoint WMD960
    And don’t touch that heatsink until it’s been off for ten minutes :plug: .
    Mike.
    #336472
    TheSpinDoctor
    Re: Hotpoint WMD960
    Hi guys. Thanks for the info so far. There has been no fault code displayed to the user, just the door locks, time counts down normally but no fill, no drum action, zip! If there is no diagnostic like Lux Group product for example & there is no fault code known to have been displayed, any help is appreciated.
    Keep the ideas coming people.
    Cheers.
    TSD.
    #336473
    Re: Hotpoint WMD960
    Have you checked the motor electrically and the wiring to it?
    As usual with these ‘Indesit’ machines in most cases if nothing obvious is found then the main PCB is likely to be faulty.
    EMW will test/repair these modules.
    #336474
    keithwilliams
    Re: Hotpoint WMD960
    hey spindoctor
    how did you get on with this machine cos im going to exactly this fault tomorrow. i know about the motor wiring probs but just curious to see if you found out something else.
    ta
    #336475
    madangler1
    Re: Hotpoint WMD960
    Normally module if its 3 phase
