Got called to this one as leaking from left(as you look) front bottom. I couldn’t find any trace of water after filling on wool wash,draining three times and sitting through a 30 min quick wash cycle with clothes in!
checked seal,dispenser box and hose to drum and all water connections at the back- nothing!
Had it tilted and checked everything under even pump etc on right side- nothing!
Next day customer calls and says it’s leaking again, husband has tilted it and can’t find any trace of water.
I also checked adjacent fridge, that’s ok.
Anyone had this before, I’m sure it’s not just this particular model as it’s the same as thousands of others! cheers Darrell
