Hotpoint WMD960 Ultima “no water”
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WMD960 Ultima “no water”
  • #70599
    rieverjohn
    Daughters 4 year old WMD690 displays “no water”.
    there is water pressure at the inlet. Possible causes of failure,
    faulty solenoid
    faulty air switch/hose
    control unit
    is there a “most likely part to fail”?
    The control unit(bottom left rear) appears to have a series of flat connectors behind a plastic panel, possibly to allow a diagnostic unit to interrogate fault codes! too sophisticated?
    #378478
    Re: Hotpoint WMD690 Ultima "no water"
    Most likely cause is an open circuit fill valve. Mains plug out and meggar or decent multimeter needed to test.
    PS. I will edit the thread title, I think you mean a WMD960. 😉
