Can anyone help please?
Our washer has developed an intermittent fault in that it will run a wash cycle ok but at the end all the lights flash with the code F06 in the main display, also there is a constant clicking from the door lock . When this happens the only way to open the door & reset everything is to power off & open the door with the emergency manual pull.
Is this likely ( as Ive been told, the door lock itself?
Thanks for that! Ill give it a try as they are only about £15. Is it an easy job to change? I dont see any screws behind the door like older machines, just 2 little plastic bumps!
