Hotpoint WMF 560 – “door” flashing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WMF 560 – “door” flashing
  • #77821
    tiresias
    I have a Hotpoint WMF 560.
    When I try to start a wash, there are six loud “clacks”, then the message “door” appears on the LED panel accompanied by 3 beeps and 3 flashes of the red led next to the key symbol.
    The door appears to be properly closed.
    Last time I did a wash, this happened several times but eventually I got it to start OK and it did the full wash without any problems.
    But for this wash, after several attempts I still just get the above error each time, so I can’t get it to start at all.
    The door mechanism seems to be OK. Nothing visibly broken and the door shuts firmly.
    Any idea what might be wrong?
    #403522
    Re: Hotpoint WMF 560 – “door” flashing
    Loose or broken motor wiring connections first thing to check.
    #403523
    tiresias
    Re: Hotpoint WMF 560 – "door" flashing
    Thanks, but why would it give a door error if the problem was with the motor connection? Surely it would give an error code that indicated the motor at fault, not the door?
    #403524
    It is an Indesit machine, nothing is logical ( or reliable) I will repeat, the first thing to check is the motor wiring plug connections.
