Hotpoint WMF540PUKR Programmer knob spins
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WMF540PUKR Programmer knob spins
  • #67382
    Saabfast
    The programmer knob no longer clicks round. Its spins smoothly but does not alter the programme. I assume that the knob is broken and no longer turns the programmer spindle? I can obtain a new knob but as it is buried in the front panel this has to come off to change it. Is this easy to access for removal?
    #367282
    BobHope
    Re: Hotpoint WMF540PUKR Programmer knob spins
    sure enough the knob will be broken, the D shaped hole where the shaft fits will be split, quite easy to fix with a cable tie, plug out if you have a go yourself..
    Bob.
