hotpoint wmf740
  • #58042
    waters
    I have only had 2 of these and both had the same fault.
    The cold fill valve is the same as the previous models but with an extra piece on the end to give it extra length.It is this extra piece of plastic that leaks.It looks like its just glued into the valve.The water then leaks inside the machine .Has anyone replaced these.
    #333193
    allan73
    Re: hotpoint wmf740
    I think hotpoint do a kit now for these which does away with the need for the extension bit on the end of the valve, sorry don’t know pt number.
    #333194
    gandh1
    Re: hotpoint wmf740
    original spec was all in one dispenser and sols + ext for the 7kg machines.
    for about £35 trade then hp replaced that part with an extended dispenser and no ext, specifically for 7kg machines at about £50 net.
    however this part seems to now be obsolete again as i just ordered one for a 740 which was cheaper and came with the add-on ext piece. for £22 net…
    not sure even merloni know what theyre up to tbh!
    #333195
    waters
    Re: hotpoint wmf740
    Thanks,where did you get one for £22 .
    #333196
    gandh1
    Re: hotpoint wmf740
    connect… of all places.
    #333197
    helo_75
    c00268761
    comes complete with valves, hopper top and bottom and inner drawer
