I’ve come across this a couple of times. The inlet valve for this machine does not reach the back so has a plastic extended piece added that though it looks like it screws on to the valves thread it’s glued (and they leak). The valve shown for this machine is just the standard valve without the extended bit. What is the part I need please anyone?
Thanks guys. I think ive found what I need.
The original part is the dispenser unit with the extended valve and is now obsolete. On connect its 5045170964788. They’ve replaced it with this 504517333206 which
is I guess a longer dispenser unit and standard valve. Plus a new back plate is required.
