hotpoint wmf760
  • #51208
    aclarke
    hi guys
    got a hotpoint wmf70 washer no pump or spin, plug in turn on pretty lights come on door lock kicks in and that it, am i rite thinking it main pcb failure and would ewm do such board if it is
    many thanx
    #307254
    helo_75
    u might wanna check the motor out… theres a neutral gone down somewhere
    id just check the pump too
    #307255
    aclarke
    Re: hotpoint wmf760
    cheers helo,dropped in new pump still no joy change motor still no luck, did notice that interlock kicks in but dont kick out even after 20 mins, so seems all it does is turn on and light up locks then no other action at all dam indesit rubbish
    #307256
    HotDog
    Re: hotpoint wmf760
    have you checked motor plug for broken wire and continuity to board
    #307257
    aclarke
    Re: hotpoint wmf760
    was the board on this way got ewm to repair it 😀
    but now need motor for it or any idea how to repair old one
    #307258
    Re: hotpoint wmf760
    Think that’s an induction motor, isn’t it? Don’t know if they vary at all but someone was trying to sell one on e-bay a couple of weeks ago and didn’t get a bid even at 99p. So they’ve probably still got it. If you’ve got an e-bay a/c sign in and look for item no. 250555348428 ( I kept it in my watching folder). Then you can message the seller and ask him to pop it up “buy it now” if he still wants to sell.
    Mike.
    #307259
    aclarke
    Re: hotpoint wmf760
    cheers leavemetogetonwithit,
    yes it is induction motor have emailed the person on ebay and waiting to see what happens if if still got it etc, many thanx for your help..
    #307260
    aclarke
    Re: hotpoint wmf760
    rite this machine getting on mi tits now sent board off too ewm to be repaired they sent it back after they fixed it, so got pump action and slight motor action then comes up with f02 which i belive is motor/tacho so changed motor still same fault, checked all wires all ok continuity to board fine and changed pump and motor as had 4 of them turn up by mistake all run slightly then error code f02 again, any ideas could ewm missed something when they repaired board or am i missing something
    #307261
    aclarke
    Re: hotpoint wmf760
    anyone?
    #307262
    Re: hotpoint wmf760
    Can only suggest ring EMW, explain situation and ask what they think. They do a couple of sackfuls of modules every day I understand, so there won’t be much they haven’t heard before. They might have another module in stock they can send out for you to try if you talk sweetly to them. (Personally, I would have thrown in the towel before this point and cut my losses – to my sanity that is.)
    Mike.
