Hotpoint WMF760 H20
  • #60328
    nelson
    I had a look at this one today customer reports that the machine locks the door then does nothing for a minute or two eventually it flashes up H20 but if she leaves the machine for ten minutes or so it will start the program and runs ok. 😕
    I checked the water feed it was ok, metered the valves was getting no power, plugged in a new pump still nothing, tested the heater was ok, checked the ntc was ok, tried a new door lock on which made no difference.
    I am thinking the board, anybody else had this?
    Any thing I am missing?
    Cheers
    #341810
    Re: Hotpoint WMF760 H20
    nelson wrote:Any thing I am missing?
    If you type H20 in the SEARCH box then click on TRADE TECHNICAL forum only there’s a wealth on info you will find so useful in solving this problem. 😉
    Oh how we love that search tool………… 🙂
    #341811
    nelson
    Thanks for that Martin, I did search H20 but nothing really relates to the problem my customer is having. I am aware that H20 is a no fill fault but the thing that I found a bit puzzling was that after it flashed H20 when left for about ten minutes would then begin the wash and operate as normal.
    #341812
    Do EMW do a board for these? If so, best option I’d say. You can always return it if no cure.
    Mike.
    #341813
    nelson
    Cheers Mike I’ll check it out.
