Hi. Need a bit of info here. Start machine, door locks, pumps for approx 1-2 seconds then nothing. Display stays lit. Door stays locked.Remove mains plug. One of the relays on the pcb clicks. I then plug machine in and the door unlocks. Have tested for earth leakages, all ok. Any info appreciated.
Assuming the motor / connections are ok, then I’m sure it will be one of those software faults. There is a reset of the pressure switch around here somewhere that can work. This fault normally happens after a blockage / when the filter has been cleaned.
Thanks for the info. I did check motor/plug and was ok.
Will pop back and try the reset though. I did notice the kick plate had been removed so I,m thinking there may have been a blocked filter before hand.
Thanks for the inputs. Recalled this evening. Reset pressure system, no joy. Re-checked 3 phase motor, tacho (114 ohms) coil readings from the remain 3 tags were approx 3.5-3.8 ohms. EMW will be getting a call in the morning. Think it may be the transformer down. Will let you know the outcome.
