This machine you set the programme and push start button.
The door locks but nothing happens for several seconds it then errors F06 with all lights flashing.
Then has to be disconnected from the mains to reset.
I’ve changed the Bitron DL-S2 interlock and checked the wiring but still have the same fault.
Any ideas?
Cheers.
Yeah could only find an unprogrammed module which isn’t any good to me.
Update…removed module and discovered a barbecued slug on the pcb.
Removed the offending slug and cleaned up the mess.
Seems to be working ok so I’ll keep fingers crossed
