Hotpoint WMG 823
  • #87105
    melec
    Can anyone give me a pointer on a recall I am going to tomorrow please.
    Hotpoint WMG823 with an F05 fault
    I cleared the sump and filter last week and tested fully for pump and spin and was perfect
    No overfilling etc all seemed uncomplicated as foreign objects found in pump/sump
    When she called me tonight I was a bit mystified so checked fault codes and discovered that signifies pressure switch jammed on trip
    I do not understand that jargon ‘trip’ does it mean pressure switch faulty??Or can I ‘unjam’
    I also saw another fault code describing a pressure switch reset? Can anyone shed any light because I have never even heard of that nor seen one
    Would appreciate it as long distance involved ( as with all recalls :rolls: )
    #433974
    greedy
    Re: Hotpoint WMG 823
    Sounds like the module still thinks there is water in the pressure chamber,sometimes they need to be reprogrammed to reset this
    #433975
    greedy
    melec
    Cheers greedy
    Good bit of knowledge ! I”ll definately do it
    #433977
    greedy
    Worth a try I guess!
