Washing machine door lock was flashing so changed door switch but fault still on. I have looked at the main control panel and there is a bit of soot deposit around some of the components but the capacitors in that area dont appear raised. Is there a common components problem that i could replace them. I have also been told it might be the motor brushes but i dont inderstand the logic in that. Before buying some can anyone else confirm that is the fix?
