hotpoint wml 730
  • #83928
    deltra
    hi, right side of machine there are 6 led.machine works for about 20min then starts to pump out and top led starts to flash 😕 i was thinking this might be f08 fault ❓ but cant get it confirmed in fault guide, any ideas please.
    #424237
    Re: hotpoint wml 730
    Error codes for this are HERE
    Top light is not used for error codes, I think that one flashes for a no fill fault so inlet valve would be first thing to check.
    #424238
    deltra
    Hi jim, def prewash light that flashes,machine is actually filling when light starts to flash,that’s why I thought f08 pressure switch you maybe right, valve not closing at appropriate time and tripping overfill? ( thanks for light reading)
    #424239
    Look out for hose to pressure switch chafing on the inside of the cabinet, seen a couple with this.
    F 08 faults are always the old dreaded 8 flash fault, heater relay stuck, allegedly . :rolls:
    #424240
    deltra
    Thanks jim
