Product number for this machine is 56802.
The door lock will make all the noises of locking and the light comes on. cycles goes through ok but you can open the door at any time and the machine will continue to operate!!!
One terminal is burnt on door lock connector and does anyone know how this could happen?
the other problem I have is that the lock C00254755 listed for the series of WML520 models is different to the one fitted. the one fitted to this unit snaps into front panel and is held in by plastic lugs not screws. it is smaller but has the fitting for the green plastic strip for emergency release. can anyone advise if C00254755 is a replacement for this or what the correct part number is
regards
Geoff
