Hotpoint WML520p
  • #40074
    geoff1
    Does any one have fault codes for this unit? The one I have has all the option lights flashing and to the side the spin and door lock light remain on?
    Will not carry out any fuctions.
    Appreciate any help
    Geoff
    #264664
    Re: Hotpoint WML520p
    The error codes are the same as the Indesit WIDL ones but that sounds like a common PCB failure. 😥
    helo_75
    im sure i read on servicenet that you read bottom to top, not top to bottom
    the fault dodes are the same, its just how you read them thats different.. im sure one of the hotpoint guys can confirm
    #264666
    geoff1
    Many thanks to you both for your help.
    managed to get some more information this morning
    You do read them from bottom to top starting with the door lock light as being number 1.
    Uses 5 led’s in all and have listed the best way I can
    led lit
    5 4 3 2 1
    FO1 off off off off on
    FO2 off off off on off
    FO3 off off off on on
    FO4 off off on off off
    FO5 off off on off on
    FO6 off off on on off
    FO7 off off on on on
    FO8 off on off off off
    FO9 off on off off on
    F10 off on off on off
    F11 off on off on on
    F12 off on on off off
    F17 on off off off on
    f18 on off off on off
    possible causes to these error codes are the same as the WIDL machines
    hope this may help
    Geoff
    #264667
    Thanks to both of you for that, added to Error codes thread. :tup:
    helo_75
    when the hell will hotpoint use their heads?
    i mean why cant light 1 be f 01
    like f05 being 1 and 4
    would make it so much bloody easier, wouldnt it?
    #264669
    twicknix
    does the lights have to be flashing or static?
    #264670
    Flashing
