Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint wml540
- This topic has 9 replies, 8 voices, and was last updated 15 years, 5 months ago by
timjam.
October 19, 2010 at 2:00 pm #58116
timjam
Participanthi , ive got a call to this, cutomer says the machine does not start and the door lock keeps clicking when start button is pressed, any ideas ?
thanks Tim
October 19, 2010 at 2:09 pm #333425electrofix
ModeratorRe: hotpoint wml540
thats funny just come back from sililar machine with same prob
removed pcb cleaned all terms and connectors
machine started changed programmes no probs
put it all back together and ran a rinse
stopped machine half way through and went back to same problemnext action would be to send boards to emw but i suggested that as hotpoint made this rubbish maybe they should bear some of the cost and claim on the free parts warrenty. so thats what she is looking into. if i send boards to emw and they work on the day then we will never find problem and after that hotpoint wont touch it
October 19, 2010 at 9:27 pm #333426helo_75
Participantthats a faulty motor that
theres a neutral down somewhere, or a broken wire
February 17, 2011 at 7:02 pm #333427cornwell40
ParticipantRe: hotpoint wml540
I have exactly the same fault. Checked the motor, all paths through ok and meggers fine. Checked the wiring from the module to motor and checked plugs (what cr*p connections in the plugs). Swapped the hinterlock still clicking like a oap’s top set (no offence Martin 😉 ).
Sent the board over to EMW and hope that’s the culprit, otherwise I’m stumped on this.Tony
February 17, 2011 at 10:46 pm #333428suedehead1
had about 6 of these the same i dont know exactly what happens but i tighten up the motor plug and it seems to work ok, although i have had to go back to one for a repeat fault.
February 18, 2011 at 8:50 am #333429Martin
cornwell40 wrote:the hinterlock still clicking like a oap’s top set (no offence Martin 😉 ).
None taken Tony. 😀
Besides I don’t get that problem now since someone put me on to Gripfill. 😛
February 18, 2011 at 12:42 pm #333430DDSDDS
i have seen this many times and it always seems to be the motor block wiring
i did have one that would not lock turned out the door hinge was bet so the pin was not quite making contact just needed bending back into shapeFebruary 18, 2011 at 4:17 pm #333431Rograbbit
Is it easy to repair motor block? What type of plug are on these?
February 21, 2011 at 11:59 am #333432DDSDDS
its not too difficult they usually pull apart
February 24, 2011 at 6:54 pm #333433cornwell40
Go the board back from EMW. Machine now works but not sure if its doing what it should. The clicking has gone but I was under the impression that when the pause is pressed, the programme stops and the door can be opened. You can change the programme but the original programme will not stop until you do so 😕
Also once the end light shows should the door remain locked. I’ve been powering it down, wait a few seconds, power back up press the start and …..the door unlocks.Plus…..PLUSSSSSS….i’ve never had to take the front panel off to swap an interlock before. I’m really beginning to dislike Indesit….no honestly 😉
Tony
