hotpoint wml540 guk door lock
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint wml540 guk door lock
  • #49206
    phil59
    hi guys has anyone replaced the door lock on the wml hotpoint with the std hotpoint indesit door lock (c00085194)
    the only difference i can see is the correct door lock has a quick relese pull handle to open the door hidden behind the kick plate in case the door handle breaks
    thanks in advance phil
    #299110
    timdowning
    Re: hotpoint wml540 guk door lock
    I’m sure this new range have a zero delay lock in them. Like the Zanussi machines.
    So I wouldn’t try the old type in it.
    This is why there is a mechanical release option on them.
    (If theres a power-cut or the lock fails electrically.)
    #299111
    phil59
    cheers ive ordered the correct one but just wondered
    many thanks
    #299112
    garn
    got one of these its eating the door locks for breakfast
    as soon as you fit them it blows and there £13.10 a shot 🙁
    Cant See This Appliance Listed In Masterpart to :rolls:
    can Anyone Put A date To This Machine Its Not That old
    L4 (54701) wml540G 901200127.
    Thanks garn
    #299113
    Thanks garn
    Date codes thread
    Its still under warranty. 😕
    #299114
    garn
    Thanks Jim Would I be Correct And Say It is June 2009 If Im reading It correct .
    And I really Would Appreciate A Part number for The Door Lock I have hptC00252.
    The Appliance has Come Out of a Repossessed House Cant See Hotpoint Calling To Fix it in my Property I would be Highly 😳
    Thanks Paul…
    #299115
    C00254755 – interlock.
    garn
    Penguin45 wrote:C00254755 – interlock.
    thanks 😉
    #299117
    helo_75
    the motors faulty, thats whats doin the lock in
    #299118
    garn
    helo_75 wrote:the motors faulty, thats whats doin the lock in
    Not Sure 😕 With The Motor Disconected Its Still blowing
    may Have to Check The Loom Or Power Flex.
    Thanks Paul
    #299119
    a1al
    Hi Phil59
    Have a WML760 machine with all lights on door lock locks but thats it, is this the same problem you had? and did proper door lock fix it?
    a1al
    #299120
    garn
    a1al wrote:Hi Phil59
    a1al
    Hi Phil
    No The Particuler Appliance I Was Working On Was TrippingIt Was The Main Power Feed To The Board It A 2 Spade Connector Block It Get Hot And Its Melting The Plastic Insulation Divider Between The Live & Neutral On The Block.
    I Was 😮 To See On This Block The Divider In The Connector Block Looked Like Metal With The Plastic Insulation Round It It Just Melted And
    It Had A Rather Large Bang & Flash 😯 .
    The Lock For This Is Not Cheap To
    Paul…
