Hotpoint WML540 Door seal
I have fitted new door seal to this machine and have got a call back as the drum is touching the seal. There is no play in the drum what so ever. The part number I fitted is C00143605 this seal has a lip that fits between the outer and inner drum and it is this that is touching. This machine has the Indesit sealed tub assembly, should it be an Indesit door seal?
Has anybody had a problem fitting a new door seal if so which one did you use? part number please
Thanks Bernie
