Hotpoint WML540P
  • #78856
    Mark1
    I have just put brushes in the motor as it failed to start washing. The lights come on as normal to the corresponding programme and the green start light flashes slowly to start the machine but when pressed nothing happens.Firstly all the yellow lights flashed quickly and the door lock and spin light on the right hand side stayed on. I am unable to switch the machine off – only by the socket. Is the board jammed or need replacing or will it need changing? Wouldnt be so bad but only changed the tub a couple of months ago||
    Thanks Mark
    #407130
    Re: Hotpoint WML540P
    Moved to Trade Technical, this is not a General Trade forum question. :rolls:
    The error codes are in the Known Error Codes thread.
    Leds 1+3 =F05.
