Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint wml730 Aquarius wont wash with clothes in
- This topic has 6 replies, 2 voices, and was last updated 10 years, 3 months ago by
Rooster66.
December 28, 2015 at 11:22 am #87139
Rooster66
ParticipantMy machine will spin on spin cycle, fill and empty with water but drum will not turn with clothes in. If I take clothes out then the drum will turn and wash. I have had motor off and checked brushes and they are fine? It will spin on spin cycle with clothes in.
December 28, 2015 at 11:28 am #434056mundaysrepair
ParticipantRe: Hotpoint wml730 Aquarius wont wash with clothes in
Hi I’m Nick I run an appliance repair business in Northampton
Take the back off and observe a wash with clothes in, does the motor turn? Possibility here of a loose belt not gripping the pulley with a load.
Let me know what happens here,
Nick
December 28, 2015 at 11:41 am #434057Rooster66
Thanks for reply Nick, I’ve had back off, the belt is gripping, the motor moves about an inch trying to turn the drum, stops and then try’s to turn the opposite way.
December 28, 2015 at 10:14 pm #434058mundaysrepair
Ok sounds like a motor fault, did you check both brushes? how long are they? are they shiny or dull and charred?
Look for soot on the motor armature next and signs of armature wear.Take the belt off and start the machine on a normal wash, does the motor rotate in both directions successfully? or does it follow the same struggling pattern?
Nick
December 29, 2015 at 11:21 am #434059Rooster66
I’ve taken the belt off and the motor turns to and frow as normal.
The brushes were new less than 12mths ago, they were shiney but not all over so I cleaned them up and cleaned the motor with some fine sand paper.January 1, 2016 at 4:34 pm #434060mundaysrepair
ok if a brush replacement doesn’t do the trick again it’s new motor time, sounds like a problem with the field winding which is unrepairable
January 2, 2016 at 7:16 pm #434061Rooster66
Thanks for your help Nick, no better so went out and bought new in the sales. Once again cheers Chris
