Hotpoint WML760G will not fill
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WML760G will not fill
  • #76178
    snacr63
    When i switch on the machine the door lock light goes solid red and there is a clicking sound from around the door lock area. (several clicks) The top orange light goes solid but it does not fill at all.
    I have checked the water feed and it is not kinked and there is good pressure. I have tried changing the inlet water valve but no difference.
    Any suggestions what to try next?
    #397479
    Re: Hotpoint WML760G will not fill
    Check the motor plug and wiring connections. Make sure you leave it unplugged for 10 minutes before you remove the back, 3 phase motor, the pcb carries a hefty kick if not allowed to discharge.
