Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint wmm 65a 1600 ultima
- This topic has 16 replies, 6 voices, and was last updated 19 years, 2 months ago by
flash.
January 17, 2007 at 9:12 pm #24238
flash
ParticipantHi need some help with this one please. had a call today on this 1600 ultima . the costomer said there was no drum action. I dont have a manual for this one , so I set the machine on a spin machine started ok then short spin and shut down there was no burnt tracks on any of the boards brushes ok any ideas please GLEN
January 17, 2007 at 10:39 pm #201235iadom
ModeratorRe: Hotpoint wmm 65a 1600 ultama
Will send you some info on WMA62, very similar machine, might help.
January 17, 2007 at 11:17 pm #201236Alanj
ParticipantRe: Hotpoint wmm 65a 1600 ultama
Hi Flash,
have you checked for the usual chaffed wiring underneath near front at balance weight, or broken wires inside insulation at motor plug?
Alan
January 18, 2007 at 1:22 am #201237flash
thanks boys I am Im calling back to the job tommorow and I will let you know how I get on Glen
January 29, 2007 at 6:18 pm #201238flash
Hi been out to put the machine on test it had error E30 I had a replacement motor in van 1604117 ac motor kit . But still the same .
Can anybody tell me if the chopper board is ment to be included in this motor kit becouse there was only motor in the box if not could the problem be the chopper board or the power mod ❓Glen
January 29, 2007 at 7:11 pm #201239iadom
That motor should be a DC motor, you have the correct part number though. E30 is tacho fault. If you get the same with a new motor I would strongly suspect a wiring fault. Never had to change a Chopper board on these yet. The individual wiring harness for each block is available, motor to chopper board harness is a 1603764, less than a fiver so well worth a punt.
January 29, 2007 at 7:29 pm #201240flash
Thanks jim I will go back tommorow . and test the motor wireing loom
Glen
January 30, 2007 at 9:25 pm #201241HotDog
ParticipantRe: Hotpoint wmm 65a 1600 ultima
Had three diffrent wma 1600 machines before christmas all no motor action they all turned out to be the chopper board very strange really never had any problems with this board ever
January 30, 2007 at 10:05 pm #201242iadom
ModeratorRe: Hotpoint wmm 65a 1600 ultima
Hi Cliff, hows things?
What fault symptoms did these machines display?
January 31, 2007 at 9:45 am #201243Tubs
Last one I had turnd out to be chopper board. Fault description, no drum action
Steve
January 31, 2007 at 8:57 pm #201244HotDog
Hi jim all the machines had same fault no motor action
January 31, 2007 at 9:05 pm #201245HotDog
sorry must be groundhog day
January 31, 2007 at 9:14 pm #201246iadom
No its you Cliff, have you not got broadband yet you old Luddite.
Removed the duplicate posts for you.
January 31, 2007 at 10:17 pm #201247HotDog
Thanks Jim just woke up had this o’rrible dream that hotpoint had been taken over by indesit and produced a horrible tumble dryer called a VTD00. Phew i’ll go and have a stiff drink now and hope everythings alright in the morning.
February 1, 2007 at 12:18 am #201248Alan1476
HI there
Had this fault a couple of weeks back and it turned out to be a chopper board. 😀 No drum action.
