Hotpoint WMM39
  • #9650
    Ralph
    Wondering if anyone can help with this one
    The washer is overfilling and the prewash light flashes then the unit shuts down.
    If anyone can suggest any ideas i would be very grateful
    Thanks, Ralph
    #135067
    Dave_Conway
    Re: Hotpoint WMM39
    Have a look at page three in the “known error codes” thread at the top of this forum Ralph.
    Iadom has posted a helpful guide that relates to most of the WMA/WMM models which may help ?
    #135068
    Re: Hotpoint WMM39
    The first thing I would check is the sump/pressure switch air bell housing, I have had something as small as £2 coin sized piece of paper covering the outlet from the sump to the pressure hose air chamber causing this fault.
    #135069
    recall
    Re: Hotpoint WMM39
    prewash flashing indicates didnt fill to level in 2 mins, check pipes etc
    but in you case i would go for sump/pipe blockage or u/s press sw
    #135070
    Ralph
    Re: Hotpoint WMM39
    Job done and the fault was……
    Blocked sump pipe filter, simple as that.
    Thanks very muchly for advices
    #135071
    jimbo2207
    Re: Hotpoint WMM39
    Pretty common fault this, sadly not documented. Probably caused by spikes on the mains, in my experience it happens in houses where hubby is a DIY enthusiast. The machine has been spiked while writing to the eeprom, this causes the program to become corrupted.
    Rewrite the eeprom (or replace it) problem will go away.
    #135072
    Re: Hotpoint WMM39
    Are you sure, the WMM39A does not have the ‘Indesit’ type module/eeprom as far as I can see. ??
