Hotpoint WMM65 – Water keeps running
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WMM65 – Water keeps running
  • #56148
    haf1zur
    RE: Hotpoint WMM65 1600 Spin
    All of a sudden it wont do anything else but have the hot water constantly streaming through it. Thought it would stop but to no avail.
    Called in a repair guy (not our usual guy as he moved somewhere) and he said we need a new washing machine. I am reluctant to think a new washing machine is required
    Tried turning it off etc but as soon as it is plugged in the hot water keeps running.
    Any ideas what may of caused this? or where to look to get it fixed?
    Dont mind doing it myself as i have previously took the whole thing apart
    Any help appreciated
    #326387
    Re: Hotpoint WMM65 – Water keeps running
    What happened to your Candy washer/dryer ?
    If it starts to fill as soon as it is plugged in then its possible you have a main power board PCB failure.
    #326388
    haf1zur
    candy washer, my sister took it while i was at work so had to get another, completely forgot about that post
    how much and where can i get a power board pcb from?
    could there be something else wrong that is causing this
    thanks
    #326389
    Not a fault I have seen on these earlier machines, more common on the later Indesit stuff.
    A thorough visual check of the whole of the wiring harness for any chafing or damage would be the first step, with the mains plug removed of course. 😉
    If you have ‘had the whole thing apart’ you may have left some wiring loose.
    Very expensive PCB’s, might be worth taking both the control and power boards out and sending them to EMW to test first.
    #326390
    haf1zur
    no, nothing was left loose as the dismantling was done a couple of months back and the thing worked fine up until Tuesday.
    i’ll double check though, hopefully if it is the pcb a soldering job will fix it, keeping my fingers crossed
    thanks for the help, wil update
    #326391
    DDSDDS
    dont think emw do the boards for this machine
    #326392
    haf1zur
    EMW as in EMW Electronics? http://www.emwelec.co.uk
    dont see a board for the wmm65
    the repair guy mentioned 100 pounds to replace the board but no idea where he was going to get it from
    hafizur
    #326393
    Very unlikely to be a bad joint, more likely the be a failed triac on the board.
    QER do list Hotpoint WMA60 series machines which are the same basic machine as this one.
    #326394
    DDSDDS
    did not know qer did them i asked emw a few months ago they said they did not do them
    has anyone actually used qer i have aways used emw
