Hotpoint wmt 02
  • #16718
    barryfast
    hi m/c starts then stops replaced door s/w, went ok for a while and stops every few seconds push start and it goes again 😕 thanks Barryfast
    #171269
    ncas
    Re: Hotpoint wmt 02
    try relay behind fascia
    #171270
    Re: Hotpoint wmt 02
    ncas wrote:try relay behind fascia
    ❓ WMT 02 is a washing machine, not a tumble dryer.
    barryfast, I can send you the diagnostics if you would like them.
    DDSDDS
    Re: Hotpoint wmt 02
    let me know how you get on with that relay i got one of those to do as well
    although i just thought it would be on/off switch pushed in and stuck i seen that before a few times makes machine reset
    #171272
    Re: Hotpoint wmt 02
    This machine does not have a ‘separate’ relay. It is not a tumble dryer. The relays in this machine are components on the control module.
    It does however have a separate start switch.
    #171273
    jd
    Re: Hotpoint wmt 02
    Hi there i have had this problem does machine fill and cut out when motor starts if so possible broken tacho wires in harness close to a cable tie you may need to trace back from motor and give them a tug as will not be obvious. hope this helps.
    #171274
    Re: Hotpoint wmt 02
    Helpful first post jd, welcome aboard. 🙂
    #171275
    barryfast
    Re: Hotpoint wmt 02
    iadom thanks for your help in the end it was the board and thanks to EMW the m/c is now running so the board was the culprit replaced the carbons and door s/w as recomended Barryfast 😆
    #171276
    Re: Hotpoint wmt 02
    No problem, thanks for letting us know the outcome.
