Hotpoint WMT03
  • #27452
    Latinlover
    Hi guys, My 3 year old Hotpoint WMT03 has suddenly decided to pump the water out as quick s it is filled, plus it just sloshes about without getting on with the job, then it just refuses to spin on any cycle. HELP the kids are fed up with their dirty clothes.
    #214120
    helo_75
    Re: Hotpoint WMT03
    is it pumping, or syphoning?
    got any flashing lights?
    could be anything, some more info would be helpful?
    #214121
    Latinlover
    Re: Hotpoint WMT03
    It is pumping all the time, and at every pump (ie every 2 seconds) the reset button flashes. It is the same on every programme, plus it does not do a spin, only sloshes about 🙁
    #214122
    timdowning
    Re: Hotpoint WMT03
    Try draining off the water into a bowl.
    Select spin.
    Does it now spin??? (it does take a while to get into the full spin cycle)
    #214123
    Re: Hotpoint WMT03
    If it is pumping all the time, either the flood protection level on the pressure switch is jammed on, or you have a failure on the computer board.
    hotpnt
    Re: Hotpoint WMT03
    could be a pressure hose/sump blokage causing just a small amount of water to operate the overfill level?
