Re: Hotpoint WMTL79 top loader
Albert,
Dunno mate, haven’t a clue. As long as you are sure the motor is OK ❓ and you have continuity thru the Field/Armature/Motor Plug connections etc.
I always try not to get bogged down with the worst senario when I come across a machine I have never seen before. But look for the ‘logical’ 😉 Like for example, I would think there is possibly a ‘Safety Device’ that ensures the motor does not ‘go’ if the lid is not locked/shut??? Look out for such…that may be your problem 😉
Module it may be but unless the Motor is suspect I would tend to ignore until I have checked all the other options.
Best of luck!
