Looking for a wee bit of help as have tried various solutions to fix but none have worked.
Basically my Hotpoint WMUD 10637 P is leaking during filling from the joint between the dispenser base and the top where they clip together. I have tried the following-
1) Cleaning drawer and jets
2) Unclipping dispenser base from top and giving the joint a clean
3) Check machine is level
4) Tried reducing water pressure
None of these have worked so I am now considering the following-
1) Remove the upper and lower dispenser parts completely, clean and then use sealant to seal the two together.
or
2) Replace the dispenser parts- ?the top one ?bottom one ?both.
Any thoughts on the options would be much appreciated.
Thanks in advance
