Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WMUD 10637 washing machine
- This topic has 9 replies, 5 voices, and was last updated 12 years, 2 months ago by
smeghead.
January 20, 2014 at 1:00 pm #79102
smeghead
ParticipantMornin all
No fill on this machine- after customer found colour catcher in filter , machine will now not fill at all on any prog
Tried pressure switch reset procedure- still no fill
Only time it filled was during a rinse (empty) i opened door & poured about 2 litres into drum , shut door and restarted, after a minute machine filled to half way up glass and carried on rinsing cycle, then pumped out to end , Tried wash cycle again, still no fill 😥
just pumps for about 3 mins.Any ideas, machine 2 years old.
Clive
January 20, 2014 at 3:36 pm #407913iadom
ModeratorRe: Hotpoint WMUD 10637 washing machine
Have you tested the fill valves, there was a punter on here two days ago with a valve alledgedly burnt out on a WMUD machine.
January 20, 2014 at 5:01 pm #407914smeghead
ParticipantRe: Hotpoint WMUD 10637 washing machine
I got it to fill during rinse cycle, after first manually filling thro drum with couple litres of water, seem to work.
I didnt check valves otherwise, as they appeared to work!
Maybe go back & couple up a valve and see what happens
Thanks.January 20, 2014 at 5:19 pm #407915iadom
Initial fill through one valve to lift the eco ball, if you fill it past the lowest level it will then fill through the other valve.
January 20, 2014 at 5:53 pm #407916smeghead
OK, I’ll pop back & plug a new valve in an see if it works, if the punter lets me- she’s a regular so should be alright.
Worth a shot , if no good , I’ll send her back to hotpoint – Shame. Hotpoint really make life difficult for us independents these days( I guess thats the point ) – bring back the WM range or earlier.January 20, 2014 at 7:24 pm #407917roy1
Had the same fault ,no fill after a blocked pump,it was a main board fault.
January 20, 2014 at 9:45 pm #407918A1engineer
its not a main board fault, however fitting a new board will cure it 🙂
the machine thinks its full so wont bring on valve, you need to either trick it into recognising water again like iandom details in his guide.
otherwise you need to reprogram the board which obviously without an emit it pretty difficult 🙁
January 20, 2014 at 10:41 pm #407919geoff1
I had one that I could not get to reset and spoke to Hotpoint.
was told to start program and leave it for up to 1hr. during this time it would start to fill.
HMM
Tried it but could not stay so returned later just in time to see the water level approaching the soap draw. Was not away for the full timeStopped it and emptied drum.
It was OK from there on.
Geoff
January 20, 2014 at 11:01 pm #407920iadom
Very useful info that Geoff. :tup:
January 21, 2014 at 6:54 pm #407921smeghead
iadom wrote:Initial fill through one valve to lift the eco ball, if you fill it past the lowest level it will then fill through the other valve.
Replaced valve, still no fill, reset p.switch again just in case, no fill!! 👿
Told to try Hotpoint ( 5 yr ) – needless to say shes never buying a Hotpoint again. Who can blame her.
Thanks for advice all.Clive
