Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hotpoint wmud 960
- This topic has 7 replies, 3 voices, and was last updated 12 years, 2 months ago by
maddie.
January 18, 2014 at 8:32 pm #79080
maddie
ParticipantCan anyone give me advice number of problems with machine.
1 no water inlet at valve.changed for new as other was burnt out also got a recondition module from a company on a exchange basis.Now when i power up and select awash pump starts for 2 seconds and cuts out and repeats it self over and over again.also water switches on and cuts of after 1 second and keeps repeating this.After about 7 mins it displays F02 fault.i have cleaned filter but found nothing.i have checked wiring on module and all are snug and tight.Any help please i am a lost with this nowJanuary 18, 2014 at 10:28 pm #407826razor
ParticipantRe: hotpoint wmud 960
maddie wrote:Can anyone give me advice number of problems with machine.
Maybe the new module faulty or wiring from motor to module faultyF02 is motor tacho fault
January 19, 2014 at 5:12 pm #407827maddie
i thought this anyway i put my old module back in and pump starts to drain with out cutting out.but still not filling with water.so i opened door filled by hand till far as i could closed door and tried to start a wash wash.surprise water started coming in from inlet valve to about just under half way on glass door and motor turning.i drained and went through same motions so i suspect i have a faulty pressure switch.i have blown down pipe all seems clear but have ordered new switch.
January 19, 2014 at 6:25 pm #407828iadom
ModeratorRe: hotpoint wmud 960
There does not appear to any model WMUD960????
There are three versions of WMD960 , there is a WMUD962, a WMUD963 and a WMUD9627.Can you give us the serial number and the commercial code from the sticker inside the door?
All have several different modules and software. As the WMUD range is not that old the chances of you getting the correct ‘reconditioned’ module are extremely remote unless you also gave the supplier the commercial code of the machine.
It is very rare for a fill valve to ‘burn out’ after such a short amount of use but if it was burnt out it could have damaged one of the fill valve triacs on the module. Filling it manually half way would allow the pressure switch to close one level and then allow it to fill from the other valve.
I fear you are tying yourself in knots with this and very much doubt a new pressure switch will cure the fault, I suspect the replacement module was incorrect.
January 19, 2014 at 7:16 pm #407829razor
sorry never even noticed that model was incorrect, think he meant WMD960.
could well be incorrect file setting on board or wrong board as you have said iadom
January 21, 2014 at 8:13 pm #407830maddie
i have spoke to company i got module off and they have advised i send both back.my original one and the replacement sent.i will keep you posted on what happens next.Thanks for all the reply s
January 21, 2014 at 8:22 pm #407831iadom
What is the correct model number, serial number and commercial code. If you give us that we can tell you exactly which module fits this machine, no g/tee that it is the cause of the problem though, there is no WMUD960.
January 30, 2014 at 10:47 am #407832maddie
Sorry about model number the correct one is wmud962.Well i sent main modules back my original and the one that was sent to me.They said they could not find any faults but sent a different replacement to try. I tried new one and hey presto its all working.Thank you everyone for all your advice and input
