Hotpoint WMUD942GUK washing machine
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WMUD942GUK washing machine
  • #94515
    suedehead1
    It trips the fusebox as soon as its switched on.
    Meggered motor heater suppressor checked door lock and wiring.
    Tried it in another socket no joy.
    It belongs to an old lady on her own doesnt seem to have been used much.
    Any ideas welcomed
    #457558
    kaibart
    Re: Hotpoint WMUD942GUK washing machine
    I know it’s a long shot but try disconnecting every wire from module then meg it.
    #457559
    suedehead1 wrote:Hi,
    as soon as its switched on from the socket or as soon as the on button is pressed ?
    suedehead1
    as soon as the button is pressed
    #457561
    so that rules out suppressor
    since motor and heater are top of the list disconnect and see if it still trips
    suedehead1
    meggered the machine to death not even a flicker off the needle at 1000 volts.
    I did however disconnect the motor and it didnt trip.
    its one of those brushless motors.
    #457563
    since we know its an earth fault see if the motor has an earth connection and disconnect that then try it
    if it does not trip then it must be motor but how your megger did not see it, well don’t know
    problem is here we don’t know how these machines boot up. it may be that with the motor disconnected then other components are not turned on.
    Did you try it with the heater disconnected ?
    suedehead1
    going back tomorrow i will disconnect the heater first.the motor didnt appear to be earthed
