Hotpoint WMXTF942 no motor action since slug attack
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WMXTF942 no motor action since slug attack
Viewing 15 posts - 1 through 15 (of 15 total)
  • #97829
    snig
    Above machine found with module blown and fried slug on board. Had module repaired by EMW but since refitting i have no motor action, eveything else appears ok. Sent board back for retest but no fault found. Any ideas ?
    #469698
    i assume you told Emw you had no motor action
    assume you have checked motor windings and tacho
    after that all i can think is its the board
    snig
    Yes to both. Told emw no motor action, they took it back for retest.
    Motor winding test at 7 ohms. tacho about 50 ( can’t remember exact reading now )
    I’m stumped as to what else it could be. Guessing it damaged something else when it blew but no idea what ?
    #469700
    murv
    Have had linear pressure sensor cause ‘just pumping without motor action’ on spin programs in the past.
    Murv…
    #469701
    snig
    This has no motor action on any program but maybe worth a try. Don’t know what else i can try
    #469702
    murv
    Do you know if the module has been swapped or is it the original one repaired?
    #469703
    murv wrote:Do you know if the module has been swapped or is it the original one repaired?
    you thinking possible software problem ?
    murv
    Possibly Dave,
    It is hard enough to work out which settings file is correct for single phase machines. Three phase are a pain as there is a main processor with it’s firmware library talking to a second DSP processor running its own motor driving firmware.
    A mismatching DSP version due to a board change can cause no motor action problems (often with no error flagged).
    It’s complicated and often impossible (without trial & error) to work out which settings software is designed to run on a particular FW1 & FW2/DSP combination. Then add the variations in motor pulley size, Solenoid, PTC or Hybrid door lock types etc and it gets very confusing.
    I usually dump the software settings file from the old module and program a used/new module which has matching FW1 & FW2.
    Murv…
    #469705
    looks like an absolute minefield. take you have spent hours on some machines before you learnt how to do it
    just back heal them myself. luckily the only slug one i had recently, I changed a diode and the power chip and it was ok
    murv
    Just do workshop jobs for the local trade (or whats left of it!) Like fixing BER stuff at component level if within my skill set.
    Not too driven by money so quite happy to put hours in for peanuts if I can keep it away from the scrap yard.
    Have done hundreds of sealed tank bearing jobs & simple module repairs on rental Merloni/Beko washers & dryers in the last few years.
    Murv…
    #469707
    snig
    Module repaired was the original one so should be ok but as you say, it is an absolute minefield. Just don’t like being defeated
    #469708
    murv
    Do you have machine comercial code + serial number. and codes from the label on the module box?
    Murv…
    #469709
    snig
    Sorry No. EMW asked at the time but doesn’t seem to have them. This is a newer module i hadn’t seen before in a brown box !!
    #469710
    murv
    One of the new ‘windy’ modules. Sorry, I have none of these available to try.
    If machine does everything apart from motor action I would check pressure sensor (unlikely), motor and tacho circuit at the module plug. Other than that I can’t think of anything but a module problem.
    Murv…
    #469711
    snig
    Yeah, thats where i’m at with it. Circuits tested from module plug. Going to try pressure switch but if that doesn’t work that will be the end of it i suspect
