Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint wt 740p
- This topic has 10 replies, 4 voices, and was last updated 15 years ago by
clockworkone.
March 31, 2011 at 1:13 pm #61985
clockworkone
Participantcould someone let me have some tech info on this one please :rolls:.paul
March 31, 2011 at 3:13 pm #348248iadom
ModeratorRe: hotpoint wt 740p
What is the problem?
March 31, 2011 at 4:24 pm #348249clockworkone
ParticipantRe: hotpoint wt 740p
got to look at this one tomorrow.lady rang up to say m/c showing f08.heater pr sw etc.stops mid cycle. obviously will go have a look for usual suspects but what really bothers me is the fact that her daddy has had a look at it before me :eeek: and i was hoping to go fully armed with wiring diag etc.m/c belongs to daughters friends familly so its hard to refuse it.paul
March 31, 2011 at 5:25 pm #348250iadom
Wiring diagram won’t do you any good. Its almost certainly the PCB that is faulty, usually best to change pressure switch as well after checking all connections first of course.
March 31, 2011 at 6:09 pm #348251johnnyj
F08 always check the element for being down to earth first, i get loads with elements going down, as iadom says usualy the module but i always stick my megger on the element 1st, JJ
March 31, 2011 at 6:25 pm #348252iadom
To tell the truth, these days I meggar the element and motor whatever the initial fault is, blocked pumps and bearings excepted of course.
March 31, 2011 at 6:44 pm #348253clockworkone
thahks jim and jj.poss one for emw.can relay be replaced easily on these.paul
March 31, 2011 at 9:56 pm #348254iadom
I have bought relays and replaced them with little or no success TBH. 😥
March 31, 2011 at 10:10 pm #348255Allsorts
I would go armed with a megger and an element and state tat the callout charge is £45 since the machine has already been interfered with by a non-professional.
George
April 1, 2011 at 8:22 am #348256clockworkone
thanks fellas.paul
April 1, 2011 at 2:23 pm #348257clockworkone
had a look today meggered element all good ntc showing 25k at room temp.cleaned all connections on module and one on control board.checked pr sw all good. has rang to say has completed 2 washes.hope it was bad conn and not sticking relay that will come back and haunt.thanks for all the help. paul
